Miltek centre
  • Miltek centre
    hey guys will a miltek centre section from an astra fit the zafira
    www.themarkwrightproject.org.uk
    www.combatstress.org.uk
    By the look of it, they are the same, I could be wrong though, lol.
      DEFINATLY, Yes probably, might do, dont know, , i fink
      Arden Blue Zaffy VXR/Standard: Sight & Light/19"/Keyless-entry, Extra added: Stage3 Re-map 285bph/up-rated actuator/Courtney-Sport Pre-Cat/Full Fredrich-Motorsport 3" 200 cell Sports-Cat Exaust/CourtneySport Intercooler/Percys 1.9 Air-Box Replacement/KW Lower 15mm springs/Brake Cooler's/76mm Highflow Top-hat inlet Powerpipe/Bailys DV26/Iridium Sparks/K&N Air-Filter/Pillar-Mounted-Boost-Gauge/insignia Washer Jets/Self-Sprayed-Parts
        yes sir. The systems are the same upto the back section.
          I think so,but I'm not sure.
          I have a split personality.lol.
            precat and cat will fit but not the center section.. i tried to put the one off my astra on to the bus and it didnt fit!!
              correct
                cheers guys
