Have I got this right.....
  • Have I got this right.....
    First time attempt at detailing, just want to make sure im using the correct stuf and in the correct order, if any of the products i have mentioned could be replaced with something in your opinion that is better value feel free to correct me folks, learning all the time
    1. Powerwash motor, Shampoo using 2 bucket method - Chemical Guys GLOSSWORKZ Gloss Enhancing Shampoo 16oz, rinse
    2. Dry motor
    3. Clay bar car with lub -Chemical Guys CLAY BAR (LIGHT) -A HUGE ELASTIC EVERYDAY USE POLY CLAY BAR 200gr & LUBRICANT DETAIL SPRAY
    4. Polish - Chemical Guys WET MIRROR FINISH ULTRA SLICK NON-STICK GLOSS MAGNIFIER
    5. Wax - Chemical guys, Either Jet Seal or XXX Hardcore Paste Wax
    WHEELS
    1. Chemical Guys Redberry wheel cleaner, rinse
    2. Chemical Guys Wheel Guard
    alot of people will start with a snow foam if you have the option of doing that
    i wouldnt dry the car after washing as claying you can just use water as lube, after the clay i would wash it again as you may get alot of loose stuff on there which if you polish it can damage again
    also aswell mate you will find your best methods of doing things, i have been detailing for about a year and i still dont know what i like to use and what i prefer, i just try different things all the time
      2. Dry motor
      WHEELS
      1.Snow form
      2.wash
      3.clay
      4.wash again
      5.dry
      6.polish
      7.wax
      dont dry then clay as u need the car wet
        Also you can do both Jetseal and wax , just make sure its wax over jetseal not the other way round!
        Originally posted by soosie
          Edited your original post:
          2. Rinse off
          4. Was again as above
          5. Dry
          6. Polish - Chemical Guys WET MIRROR FINISH ULTRA SLICK NON-STICK GLOSS MAGNIFIER
          The above is not a polish mate so it will not help to correct any defects that you may have such as hazing / scratchs. If you do want to polish then try Autoglym Super Resin Polish
          7. Pre wax clenser, such as Dodo Juice Lime Prime Lite or Zymol HD Clenser
          8. Wax - XXX Hardcore Paste Wax
          WHEELS
          2. Chemical Guys Wheel Guard[/QUOTE]
            Not 100% true as some clays need proper lube whilst some clays will also work with water
            Water on some clays is not enough to lube a car and will in fact make more of a mess of paint work and can create more swirls and scratchs
            As long as you do the general above then you will be fine, i tend to
            Bilberry wheels
            rinse them
            Snow
            Rinse
            Wash using 2bm
            Clay (with optional lube if necessary)
            Wash (find snow is not quite enough after a Claying)
            Rinse
            Dry
            Polish
            Was/Snow
            Dry properly
            Wax
            and then Smile
              clay with only water . thats heading for dissaster .
              think what he meant to say was no point drying the car before claying as it`s gunna get wet anyway followed by another wash then dry .
              with the saying claying we all know a lube will be needed and those that don`t know should read up on it 1st or ask
                Some clays also can just be used with water
                they are also sold like this and i have sued some of said clays They work just as well as some theat need lube
                  name them and post details .
                  i`ve yet to see them and as every pro detailer recomends a lube you finding could be interesting .
                    There are loads mate, check any Detailing shop.
