What polish do people use for there Arden blue VXR ???
  • What polish do people use for there Arden blue VXR ???
    What's the best polish to use on Arden blue ?
    What Make, cost and place to buy ???
    chem guzs ez cream
    then petes 53 wax x 3 coats
    then some autoglm super resin or megs hd
      Originally posted by A2ON View Post
      chem guzs ez cream
      Looks mint mate
      Where from and how much does it set you back ?
        chem guzs ez cream
        isn't that a bit backwards/ pointless, i mean you've added a wax layer for protection then srp? i'm no expert but i think its backwards?
        Corsa VXR now sold
          Dodo juice B V Pro, Dodo diamond white, Celeste, QD Zaino Z8,
            juciy jen on here sells the stuff at a very good price..
            i will agree with arron on the Ezcream...
            i use
            Dual action Polisher
            778
            Ezcream
            jetseal
            poorboys blue wax
            and loads of Microfibre cloths
            Get the MF cloths from here as other shops etc charge over the odds for them
            http://cgi.ebay.co.uk/36-ULTRA-SOFT-...es_CarParts_SM
              just use anything half decent it will look good
                or the cheap alternative
                fairy liquid( the yellow one)
                scouring pad with yellow spongy side
                dried with T.towel or bath towel
                Wheels cleaned with bleach
                The misses conditioner for the final protection
                and then some peanut butter to dress the tyres
                  if you going to do a polish mate.. i would give it a clay first then paint cleaner (dodo lime prime) then autoglm super resin polish ....then a wax or sealant
                  wash
                  rinse
                  clay
                  wash
                  rinse
                  dry
                  paint cleaner
                  polish
                  wax or sealant
                  you will get the best results from using a machine polsher .... dual action (DA) or rotary people tend to use a DA first to get used to using a machine polisher...
                  hth paul
                    so that's your secret brett pmsl
                        yeh sorry typed in wrong order
                        All bits from juicy jen ! did me a good deal
                        see my project thread mate the kit i brough is on one of the first few pages
                        initally i did
                        washed
                        clayed
                        washed
                        dryed
                        ez cream
                        megs tech 2 wax
                        3 x layers petes 53
                        as said get loads of microfibers.
                        Have you clayed before i hadent but its so easy and not at all like i expected just plenty of lube
                        ( wash solution and water) much cheaper and works fine . good luck
                          Again depends on how much effort you want to put in
                          SRP by hand then a couple of layers of Purple Haze pro or if you got a bigger budget id try Celeste Degelio (spelling ) Or BlueVelvet pro but i not tried it yet
                            Originally posted by maf View Post
                            Looks mint mate
                            I'm afraid you have been wasting your time if that's the process that you follow as you will be stripping the wax off with the SRP as the SRP is the polish, that should be the first thing, then the glaze and then the wax
                              initally i did
                              washed
                              clayed
                              washed
                              dryed
                              ez cream
                              megs tech 2 wax
                              3 x layers petes 53
                              mate you have got far too much going off there with regards to the wax and you don't really need to be using two different sorts of wax and having 4 layers on the car. A wax ideally need to be left 24 hrs to cure before applying the next wax and I don't imagine you have taken 4 days to wax your car. All you will end up doing is taking the previous layer of wax off with the one that your putting on so ending up with no extra portection and alot of wasted time and wax
