ipa?
  • ipa?
    Is this what i need?
    http://cgi.ebay.co.uk/IPA-ISOPROPYL-...#ht_2638wt_804
    Originally posted by Bobbyp90
    South East Regional Organiser
    PSN: TomFL12
    What to clean the glass in your car ?
      to get rid of dust and polish residue?
      PSN: TomFL12
        Wash the car again ???
        We tend to snow and rinsh off after a polish and its never caused us any problems.
          ah fair play. Ordered my DA for delivery tomorrow
          PSN: TomFL12
            PSN: TomFL12
              Echo
              Echo
              echo
                Ralph washin again has no bearing on professional use of isopropanol and it's uses in a detail, agreed it will remove dust but some fillers will still be left after washing again and only a proper ipa/water wipedown will show the correct state of a panel ready for lsp and most professionals would do this especially when the next process is a cross bonding sealent, washing again and snowfoaming is definitely not the answer especially as some paintwork marrs so easily after high gloss polishing that the most delicate touch is required and why alot of pros switch to Da from rotary to do the last stage. I've just this morning finished a 25 hour detail on a MK1 RS and I had to finish it with a DA because it marred badly when glazing with my festool, to then snowfoam and wash it again would have been detrimental to the open finish I've created. I would honestly advise 50/50 water ipa mix gently sprayed and wiped off with a fresh microfibre and if you've got dust everywhere anyway your not polishing correctly because 90% of products end as an oil and they are obviously not being broken down correctly.
                You can buy ipa in your chemist but it will have to be ordered in.
                I think first and foremost you should be learning to work polish so that no dust is left.
                Everything upto a compound like fastcut plus should leave no dusting at all and compounds are not needed on vx paintwork really except in extreme circumstances.
                I have 25 litres of ipa , if your really struggling I'll bring some to trax for you.
                  It's good for ensuring that no grease etc is left behind. I.e can be used before applying vinyls
                    Yep and makes up most of the ingredients if wrap cleans etc.
                      what he said
                          order of ipa it is then cheers for use advice too marc
                          PSN: TomFL12
                            Sorry i should have been clearer in my posting, i never meant it wasnt to be used but for average joe with his DA who is not Pro (sorry tom ) is it really necessary and then to start adding another product into the loop.
                            We have always snowed a car after a polish (not washed as such slip of tongue) and its not caused us any harm yet
                            And dont tell me about Marring, when we did the BMW it was 5pm and it was being picked up at 8, we had to then go over with a DA after
                              IPA will be added to the loop, its a lot easier than re-snowing and makes more sense...
                              50/50 IPA/water in a bottle, spray on, wipe off, have a looksey, be happy, smile, move on lol
                              PSN: TomFL12
