Quick Question
  • Quick Question
    Is this ok
    Auto Glym Super Resin Polish
    then
    Dodo Juice lime prime pre wax cleaner
    then
    DoDo Juice Purple Haze
    thinking of using this on my Arden Blue VXR, but unsure if im undoing all my super resin polish by following it with the pre wax cleaner??
    Originally posted by plr06 View Post
    Is this ok
    then
    then
    Have you already bought them? I'd SRP then use dodo juice blue velvet wax.
      not yet mate, wasnt sure where to go straight from SRP to Wax or if i should use the pre wax primer after the SRP first
        are you applying products by hand ??
          You do not need to use Lime prime after SRP, they both contain Micro abrasive things.
          I always go Polish to wax
            car by hand -
            SRP
            EZglaze (great for arden )
            purple haze wax
            wheels -
            SRP
            jetseal 109 ( 2 coats )
            apply products sparingly as little goes along way plus too much is a waste as the excess just gets buffed off .
            you`ll be better claying the car / wheels before applying any of the above
              Originally posted by Daz View Post
              car by hand -
              SRP
              purple haze wax
              wheels -
              SRP
              SRP by hand.
              Dedication there Daz!
              Corsa VXR Arctic Edition
                It depends mate.
                If your trying to mask defects such as swirls then use SRP bbut if you follow that with a pre-wax clenser then it will pull out the fillers in the SRP.
                So it depends what your doing.
                  doing it by hand...thanks for the help guys
