Best polish/wax for a White car...
  • Best polish/wax for a White car...
    Firstly let me say that I'm after a cheap (as reasonably possible) polish and wax for a white car (corsa arctic). I'm new to detailing and getting a friend to help me. I'm using his machine polisher so the polish needs to be ok with a machine polisher. He has applicator pads, sealant, clay, lube etc. I'm just going to buy my own products so im not too cheeky. I don't want to be spending £100etc.
    A quick basic sequence of what I should be would be much appreciated. I only want a basic detail guide as I've seen how long some people can go on for.
    Thanks for any help.
    have a look on detailing world mate, plenty of helpfull people on there
    as for wax i use dodo juice diamond white
    corsa arctic edition #257
    now sold
    REAR STRUT BAR FOR SALE!
      Yeah I was looking at that wax? Any good?
        havent really used anything else mate so can't compare
        i like it tho
        now sold
          basic process:
          snowfoam - if you have it
          pressure wash
          wash 2 bucket method
          pressure wash
          clay
          wash again as above
          pressure wash
          dry
          polish
          pre-wax clenser
          wax
          what sort of machine polisher are you using and what experience do you have using one. as for polish autoglym super resin polish is a good all rounder and will help to remove and amsk defects.
          as for a wax, white is a basic solid colour, has not metallic flakes in it. if your looking for cheap but cheerful then i would recommend something like chemical guys petes 53
            Depends on what your looking to do really. As your not looking to spend hours then I would say it's an enhancement that your after. You could use something as simple as dodo juice lime prime on a polishing pad, which will achieve a result better than than achievable by hand.
            Alternatively if want to do a correction how about some sample pots of the 3m range, these are 250ml and more than sufficient to do a car with.
            Wax wise dodo juice diamond White panel pots for around a fiver and will give you around 6 to 8 coats, or as Jay said petes 53 from cg is a cheap but decent wax. Alternatively you could use something like cg black light
              you can buy a sample pot of dodo juice , super natural is best on white IMHO , it is diamond white but better
                Forgot that one bit more expensive too
                  Well it's got a few chips in the paint which I'm going to use a touch up own to fill the polish and wax in also to smooth over. It has a few swirl marks which I also want to remove so would it be a correction?
                  I know it's not a rotary polisher. He said it's just a beginner one. Ive only ever once used a machine polisher but he has done it alot and has offered to teach me.
                    id probably say Supernatural too...
                    Previous Owner of the Carbon Edition VXR - Stage 3 [Airtec + Remus] Carbon Alloys and Rocker, Blue 356mm Ksports, Roose CDTI & Black Samcos, PPP Tophat + Boost Pipe, Quaife LSD, H&R Race Springs, Black Whiteline RARB, Blue SMD Conversion
                    **Audi R8 FTW & Progress thread**
                      Crystal coatings are starting to prosper better on white now i think. Donor car with Miracle crystal technology coating , rather sexy i think.
