best place for
  • best place for
    iron x?
    also are people just using this instead of wheel cleaner?
    fancy getting some!
    oh and do you spray on the bodywork after foaming and washing? or after foaming and before wshing?
    ta
    £12 a bottle from cleanyourcar
      cheers just on there now - out of stock
        Whenever you use it your need to rinse afterwards but we use it before claying when used but you really need to get it rinsed thoroughly (sp) or you can cause the clay to go funny
          For wheels, Try some Sonax Full Effect Xtreme wheel cleaner (not the cheap "sonax wheel cleaner" as theres two types) it works like ironx and really does clean very dirty wheels
          about £15 for 500ml so not the cheapest but i think it's the best.
          Dan_vxR
          VXR Torque of the Devil
            Does it react atol or stain your drive way?
              It hasnt so far but 90% of the product is washed with lots of water as it dont really drip off as such it just runs ?
              buy the time you rinsed off and washed water away i cant see a problem, cant be any more harmfull then Bilberry ?
                After using ironx and rinsing it off i use Tardis to srtip away whats left and attack the tar, once fully rinsed again it will be safe to clay bar and easy to remove what the ironx and tardis didn't shift.
                  Cool mate, was just wondering as its sounds pretty tough stuff with its name
                  So it doesnt shift tar spots?
                    It depends on your meaning of shift
                    Valet pro citrus tar remover wont remove tar untill its wiped
                    I think it will help to break it down mate
                      Cool what i ment was it doesnt also act as a tar and glue type product?
                        so to clarify -
                        foam
                        rinse
                        wash
                        rinse
                        IRON X
                        rinse
                        how long do you leave on wheels for?
                          Originally posted by YTVXR View Post
                          so to clarify -
                          foam
                          rinse
                          wash
                          rinse
                          IRON X
                          rinse
                          If it was me i would
                          Foam
                          Rinse
                          Iron X
                          Rinse
                          Wash
                          Clay
                          Rinse
                          Dry
                          I havent used Iron X so just how i see it?!
                            http://www.shinearama.co.uk/product.php?id=CPX-IRONX-16
                            or this which is better value!
                            http://www.shinearama.co.uk/product....RONX-REFILL500
                            Pm me and ill give you discount code.
                              I was going to sugegst that Marc, a good alternative is the Brake Duster, Iron X should be back in Friday.
                              Marc, you seem to be a big Shinearama fan at the mo. not offened you have we!?
