Wheel Cleaner
  • Wheel Cleaner
    Thought I'd tried everything until today when I got some alloy wheel cleaner called Wonder Wheels...........fantastic!
    You get a brush to apply it because its that harful to skin and I should know, I still managed to splash myself and burn it did
    Brushed on, left for a minute and hosed off........leaving them immaculate!!!!!!!!
    I even brushed the stuff on the calipers with same results!
    WHAT DO YOU USE OR RECOMMEND
    Cheers,
    Clint
    Re: Wheel Cleaner
    i agree, its the best stuff i know of!
      soapy water and polish / wax meg's that is.
        Wonder Wheels is a very acidic cleaner, yes it will do a good job but also damages laquer on wheels if used regularly.
        Try Megs APC diluted 2:1 it's non corrosive and does a very good job
          Re: Wheel Cleaner
          Cheers,
          Clint
          i bought some from halfords yesterday. im plannig on using only a once every couple of months if that. good stuff though!
            yeh i bought some megs wheel cleaner spray it on then just wash it off then put a bit of polish on and clean then been putting wax on as well just to see if it will keep the cr*p off a bit longer , need to get em off though and do inside
              Totally agree with robbie...
              Wonder wheels is fine on badly pitted wheels but any chips in the laquer and it will eat in and end up with milky look........
              I also use megs apc diluted 1:2 or 1:4 if wheels kept clean....
              Try coating wheels in wheelguard or similar and shouldnt need more than a rinse and quick clean without acidic formulas
              Wheel guard
              http://65.61.142.45/product_p/whegrd.htm
              Megs apc
              http://www.cleanandshiny.co.uk/Produ...ProductID=9871
                I've been using a product called MC2 on the Golf for the last 5 years and been really happy with it. Although this is the brand name by Swissol, the same product is available much cheaper and is called Virosol.
                  Wheel guard
                  Megs apc
                  Is this correct as it says its for interiors, will it be good for cleaning the alloys.
                    Totally.................
                    Most people use it diluted 4 to 1 because if its kind to your interior it has the properties to do your wheels without attacking them....
                    I use it all the time as do most people!!!!!
                    Dont forget to get the matching bottle and foaming spray head with dilution rates printed on!!!!
                      Sorry Marc what does this mean (dummys explanation please)
                      Just used water today as its only a day old. Used some meguiars nxt all metal polish on my alloys today after i washed em and they look real nice and shiny.
                        1 LITRE BOTTLE COMES WITH SEPERATE SPRAY HEAD WHICH FOAMS THE APC UP SO IT WILL FOAM ON WHEELS
                        THE BOTTLE HAS A MEASUREMENT ON THE SIDE TO SHOW WHERE TO FILL WATER AND FILL APC TO......
                        HPE THAT HELPS... :wink:
