Snow Foam
  • Snow Foam
    where is the best place to get snowfoam from and do you need a PW??
    http://www.vxronline.co.uk/forum/showthread.php?t=19105
    ordered mine a couple of days ago, and got it already, really good
      got mine from there aswell , you can use snowfoam using an gilmore hose attachment but i`ve switched from the hose attachment to the foam lance (which you need a pw ) .
      there`s some vids on you tube showing the snowfoam lance in action ,
      heres 1 to look at but i`m sure vxrmarc has better ones
      http://uk.youtube.com/watch?v=0S7X0r...eature=related
        Do you wash the car with a mitt with the foam still on? Or do you rinse the car and then wash?
        Sorry, just got mine and looking forward to using it this weekend!
          Foam and leave , do not wash with foam on car because you will be rubbing around all the contamination the foam eats into ....... Leave for 5 minutes and pressure wash off then start your 2 bucket routine....
          Jesus that guy with the R8 has the foam set on miles to direct , should be more fanned than that...
            oops , not the best vid to show , i`ve changed it to one thats beeing used properly ,
