Stickyness after removal of Tints
  • Stickyness after removal of Tints
    Hi I have just removed window tints from my Vectra GSI and now the windows are covered with annoying sticky goop. It makes the window make a loud screeching noise when opening or shutting. Plus it looks dirty.
    Is there any tips I can use to get this stuff off?
    You'll need to use a body solvent to remove glue left behind, something like Megs Body Solvent, Auto Glym Tree Sap and Tar Remover
      Is that you in that pic Robbieben??
        Yes mate, last summer at one of the shows
          if your names not down your not coming in!
            update on tints.... weve just tried white spirit and to no luck. the sticky stuff is on the whole window not just sections. It's like the top "tint" bit of the film came off and left all the glue and gunk behind
              Megs Body Solvent removes the glue residue thats left behind by tints, white spirit wont touch the stuff, you could also use thinners but keep it well away from paint and trim.
                will stick to the megs... think it maybe safer than me playing with thinners i just kno how hard i try not to spill sumthin it wud just happen
                thanks
                  thanks
                  If you want to use thinners just wet the cloth in one small area
                    will let hubbie to do that... his car if it gets ruined
                    im in charge of workin on the paintwork to get it back to a better finish.
                      You might want to try baby oil or WD40 if all else fails.
                      I know you may think it strange but it really works well on some glues
                      See My Wheels
                        i wont ask how you found that one out :wink:
                        thanks... i will give it a try i have some baby oil i cud use.
                          I have used lighter fluid but try in tiny area first with small amount!!
                            Oooops I forgot to say.......you will need something to clean the oil off after,either spirit based or detergent
                            See My Wheels
                              Any joy has it all come off?
                              See My Wheels
