found a polisher
  • found a polisher
    but how much is 180 us dollars in uk pounds :?
    £92 ish
      thanks
        the polisher on autopia comes with i think a single polishing pad, can these be reused each time? after washing and is it possible to polish the car using one pad or so u need say 2 or 3 one to apply and one to take off
          If your gonna get one from Autopia invest in the Sonus SFX Kit, it comes with several pads. They can be reused, simply brush off excess polish once dry and then gently soak and massage the pads in warm soapy water and then rinse thoroughly. However these pads will wear out eventually.
            Also whilst you're on there, you might want to get a 4" backing plate and a 4" SFX kit for awkward places
