porter 7424
  • porter 7424
    Got my porter today how do i get it work over here it has a 2 pin plug do i cut
    that one off and put the round 110 one on???HELP
    You need to cut that two pin plug off and fit a 110v plug.
    You'll also need a 110v Transformer and a 110v extension lead.
    These are available from
    Here
    Others may advise on which Transformer's required KVA rating etc as I don't have a PC myself.
    HTH
      Ah yes you will need a 110 convertor with suitable wattage (blew my first one , cheapo plug convertor from Maplin with only 45 watt rating ). I'd recommend this http://www.beststuff.co.uk/pbright_vc750.htm. Costs 54.99 (including delivery) but it's the cheapest I could find that had the appropriate wattage and doesn't require changing the plug from that on the PC. Ordered mine and it arrived about 3 days later - good service from the site and they even emailed me to check when was best to deliver as it's done by courier and needs to be signed for.
        That link is not working
          Ah, yes. I forgot that along with the goofy steering wheel placement, you guys have that goofy electricity/voltage/wattage thing. :P
            Soz not sure why try this http://www.beststuff.co.uk/voltage_conversion.htm and look for for the 750 step down converter for 54.99 :wink:
              Don't forget NTSC vs PAL either
              Oh, do you know what a roundabout is as well
                Oh dont forget we have a garage and they have a carport big enough for a car and suv.......and a workshop...
                Hence someone posted on autopia....."geeeezzz...look at the size of the port he,s working out of????"
                  I have never experienced a roundabout, but wifezilla did when she was out there last November and got sick as a dog in the taxi She said the dude was doing like, 50, and had to go around three or four times because the idiot kept missing the turnoff.
                    We just bought a new house, and my ONLY requirement was a three car garage. Am putting cabinets and a floor in it this week. Will get pics up when I'm done. I actually love it more than the house itself
                      My father works in texas and surrounding areas and always tells me that everyone has to have a workshop.....Its tradition!!!! :wink:
                        You should see the magic roundabout at heathrow - it's a main roundabout with 5 mini roundabouts as it's exits It's called the magic roundabout due to the amount of americans that get stuck on it and can't find their way off
                          That would be me. After about the fifth time around, I'd finally say "I know I've seen this section before."
                            I'll wave at you next time I'm there
                              is that not at hemel hempstead ??? http://www.hemelweb.demon.co.uk/history.htm its great when your in a big van
