wheel spinning
  • wheel spinning
    best solution for getting out of wheel spinning?
    powering out of it?
    changing gear out of it?
    pushing the clutch in to regain the traction?
    What about controlling the throttle a little better?
    sigpicAstra VXR Time Attack Build
    Follow me on Facebook at JK Motorsport
    https://www.facebook.com/JK-Motorspo...7132121985280/
      +1,
      The throttle is not a off / on power button, it does have settings in between
        powering out of it?
        Driving lessons maybe.
        Sir Dale Of Yorkshire
          He posted up 10 threads yesterday that's gotta be a record
          If you call these people up they'll help you learn how to drive properly
          http://lanesschoolofdriving.co.uk
          WG Motorworks Fully forged Astra Vxr Arctic ...
          Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
            Gunna go all through the posts he put up last night just to make sure he got answers for them all
            And i have never heard of powering out of a wheel spin.... The reason you spin wheels is because you are to heavy with the pedal you don't increase that
            changing gears will help stop it, when you are sat at the lights next time wheel spinning go from 1st to 6th that should help
              And then go back to first
                Turn the TC on
                Vectra VXR 280 . Courts Rad and Intercooler. Miltek cat back. K&N Panel. Eibach's. TD 1.2s
                  Good tyres
                    flat tyres.
                      HaHa! A bitof sympathy with the throttle is the best answer
                        hahaha pmsl
                        arden blue
                          Bset solution is not to spin them up in the first place, unless that's what you're trying to acheive...
                          I just let them spin a little through 1st with the T/C keeping it in check. If it's a nice day it'll hook up when you get in to 2nd. If it's cold or wet, then you just have to be gentle with the throttle.
                          Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
                          CS Mapped 285 BHP / 340 Ft.lbs
