Originally posted by Geordie076
View Post
taking corners
Originally posted by bevxracing View Postcontinental contact 3
as has been said the rule of thumb is slow in, smooth round , and fast out, listen to any race car on tv etc where they have incar footage (even F1) you need to balance the throttle to the grip available , hitting the throttle too early in a bend is just going to upset the handling and cause you problems (spin) even at 30mph if conditions are not good it is very easy to spin a car, heck i spun at 25mph going into the pits at a very wet Silverstone lol .Tuned by RnD Motorsport
Glad I'm not the only one lol. From a few of the first comments I thought it was just me haha. I'm going to look at doing a rally day for some fun then going to have a look at some lessons as I have been told you can get them to help you keep the car under control.Originally posted by Geordie076 View Postnot a bad tyre so you can rule out that,
Best way I learned to handle a FWD car was buying a 1.2 punto and absolutely hooooning it through some country lanes. Also driving in ice & snow teaches you a hell of a lot about car control, whether you like it or not!
I went from the punto to the VXR, and all the skills are transferrable really. But when it does let go you're going much fasterYes Mr Officer, it's completely standard...
I found my astra extremely sketchy into corners, everything feels electronic and so light compared to previous cars.
Will take some time and just make sure, bushes, ball joints, tracking etc is all in good order. I've uprated/replaced most and its made one hell of a difference.
Are we talking track driving or hooning it on the road?
Aside from aftermarket dampers, springs and ARBs; tyre pressures make a huge difference. After you've done a few hot laps and the tyres are getting hot, check the pressures. You'll probably find they're sky high! I run 38F / 35R set cold on the road, but I use 35~32F / 30R set hot when on the track. I find on circuit, oversteer and rear end instability into corners is the biggest handling problem. Reducing the rear tyre pressures makes a huge difference.
Just don't go too low, and remember that when the tyres cool the pressures will be too low, so you'll need to adjust them upwards again.
Sweet_VXR, what tyres and suspension are you using?Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
CS Mapped 285 BHP / 340 Ft.lbs
Originally posted by t6ngj View PostI tend to check mirrors and signal first before turning a corner...Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
A good mate of mine is a traffic cop and he explained inertia and how it affects cars basically these guys are trained to take bends at ridiculous speeds and his top tip (disclaimer try at your own risk and i would advise practicing at a track day etc than on the public road) is to take the bend at one speed dont break or accelerate until you are out the bend. I have tried this myself be good to know what others think.
The key to police advance driving is to recognise the limit point and adapt your driving accordingly (check Roadcraft) and don't forget light standards/phone poles are always on the outside of corners!
Originally posted by Craig 522 View PostLet off/brake if necessary as you come into the corner and power out the apex, doesn't change if it's street ot track imo as a corner is a corner 😊
If you go in to a tightening bend at what you think is a safe speed, and then let off the throttle as it tightens, you may find yourself exiting the road backwards through a hedge...Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
