Can anyone help, im looking to buy the 3 gauges boost oil temp oil press but also need the parts to fit ie plate ect where is the best place to get them from?
thanks mate thought so, also as ur the man in the know can i use that item to do oiltemp and oil press both off the same thing? or would i need the pressure sender?
As it says it can do both, thinking can u run them both off one ?
sorry just looked on ebay as to whats in the box with the gauges and the sensors are supplied with them The purpose of the plate is that it fits inbetween your engine and oil filter and it gives you somewhere to fit the sensors into they go in where the silver plugs are
