1st serivce
  • 1st serivce
    would my car be tack and ballanced under a service?
    also what is carried out under 1st service..
    front left trye worn on inside its say 1cm wide and angeld onto side wall where its worn,,, all other wheels/ ytyres fine and not pulling to one side
    VXR8 LS2 6.0 Auto... Nickel silver build 0087
    No they wouldn't check your tracking on the Service, Its generally just an Oil/Filter change and general check in the 1st service.
    If the tyre is unevenly worn its either due to Tracking, Balancing or Under/Over Inflation. So replace the tyre and check all 3 of the above and it should be fine
