brake fitment
  • brake fitment
    Hi guys I'm looking at getting some wilwood 6 pots done as a kit for the vec to fit the standard 345mm discs. The guy who'll be doing the kits says it should'nt be a problem but wants to know if the astra, zaffy etc would be able to use the same fittings as the vec so he could also sell it as a 345mm big brake upgrade. so can anyone tell me if the caliper mounts on the hub are the same.
    cheers Ross
    #1
    they are not the same sorry to tell u the only reason i know is because regal sell the vectra set up for the corsa and astra and they had to make brackets for them to fit
    hope that helps
    Regal dare devil AST's, Nortech manifold Garret GTX28 turbo.
    RSS Corsa
    BBC#29
      Cheers knew the corsa would need brackets but thought the astra would have same hub mounts what about zaffy and non vxr vecs any ideas
      #1
        zafft vxr is the same as the astra but not sure about non vxr
        RSS Corsa
        BBC#29
