Creatine and protein should be consumed within this time as your body is already starting to break down all the nutriants to repair its self so feeding the machine straight away helps with growth.
It depends what you're after buddy. I was going for size and power so i have a shake in the morning with a light breakfast, then either a protein rich lunch or another shake and some carbs ( not too much tho ) then would have one after my work out with creatine then a healthy dinner. I'm no expert but no one really is its more about trial and error and how your body reacts. A good tip is get a good pre work out substance. This helped me alot when I plateaued. I'm 5ft 5 inches so only small.I started at 9st 2lb last april with a maximum bench press of around 45kg,and I stand now at just under 12st benching 120kg and still gaining.
Theres alot of information out there mate about diets and excercises just have a google.
ok thanks for the advice mate yeah that's I wanna do is increase my muscle size and strength too
What sort of food should I be eating?
Do I have to drink loads of water after the creatine?
Scooby gone now driving an astra 2.0 turbo 200+ xpack
I'm looking to build muscle but lean rather than out and out size. I'm quite broad anyway so just going for a better shape.
I only have a shake before a work out, but then rice and chicken after for dinner. My diet is definitely not the best for training, but on the other hand it's not unhealthy. Just looking to get better results.
Since I started taking the protein shake, I've seen improvements, but as I say, I only have one shake on work out days. Not sure I want to get into the routine of 3 shakes per day.
Just trying to improve my knowledge on it all mate. Healthy mind + healthy body and all that!
It's best taken after, and as above it's best taken with some simple Sugary liquid.
Creatine itself dosnt cause muscle gain. What it does is replenish energy sources when your conducting short, multiple high output bursts of phys with short recovery periods between. So towards the latter sets of reps you may be able to squeeze out an extra couple reps.
If your already having a high meat content diet it's effects will be minimal if any at all. Some people recieve as much as the body needs so any surplus will be flushed down the toilet.
Also the old fashioned load period has now been found to be lacking any evidence to support it. Just go straight to the normal intake.
Plenty of chicken fish and rice mate you cant really go wrong. And green greens.
Aslong as you have a healthy amount of water each day i wouldnt worry. Creatine cycles are 3 times a day for the first 4 days. Then 1 after your workout for 2 weeks. Then come of it for 2 weeks and repeat the process.
As said creatine does not directly affect muscle growth.
I find i ache less the day after when im on creatine however.
Between a balanced diet plenty of water and the odd vitamin boosting suppliment you cant really go wrong. What contributes to gains more than anything is how commited you are when working out. The last 2 reps may be the hardest but they are the ones that have the biggest affect on muscle developement. Also its not about lifting the heaviest weights you can all the time. Mid range weights with more reps are just as important. The only reason I mentioned about my benching weight is because that is how i physically measure my gains.
It's a fabulous supplement and so well researched but as they say, companies have a product to sell and the more you use the more you buy.
Best advice ultimately is knowledge of the product your buying.
Learnt about ATP and how creatine works, this will allow you to decide if it's suitable, if your using it correctly and ultimately if it's going to be beneficial.
Many moons ago I spent months on it with limited gains visually, but physically it was superb. At 9 stone I was dumbbell pressing 27.5 kgs (each arm not total) and squatting silly weight.
My body had give up now but the abuse was fun at the time.
Yeah I agree, a good balance of reps and weight is key, have used this method for years. I am however bad for "doing" my sets and stopping at the number, say 16 reps and weights go down, am starting to try and squeeze out one more or so and also reduce rest periods as much as possible. I work out at home so not having a trainer makes it easy to not push yourself as hard.
I'm the same with the bench weight, only way I can monitor my progress as my dumbells are maxed out due to the weight blocks being the sand filled plastic. Should really invest in iron ones so I can keep progressing.
