help fitting alpine hu
  • help fitting alpine hu
    where do i connect the red acc wire what comes out of unit ?
    i know nowt about electrics so need realy simple instructions
    Not 100% but thinking back the red the wire is the steering wheel controls wire. Do you have a connects 2 adaptor?
    I see dumb people.......
    .....they're everywhere
      In any case i'd check the wiring diagram that came with the unit should hold the answer.
        had a look at diagram and it needs connecting but where ? it`ll be so simple i guess but i`m not sure and don`t want to fooook it up.
          without it plugged in do you get power?
            Think that wire need to have a constant +ve feed. i.e. from the fag lighter.
              no!!!!!!!!!lol not constant live cosit will flaten your batt!!!
                How does the radio keep a memory, with out constant power?
                  If you have to run a live feed just wire it so it only starts up on ignition. If you've got the right adaptor i'm pretty sure you don't need to run a live feed.
                    I had to get an ignition live wired in as one wasn't there
                      been told to find the ignition live wire behind glove box , gunna have a go tomorrow at finding this myself ,
                        does anyone know where i find the ignition live wire ?
                          mate, on the fag lighter there should a spear wire tapped up that isn't used which is constant live.. I went to halford to get mine sorted as I had the same problem.
                          which HU do you have?
                            alpine w202
                            i`ve wired it up to a constant live and was told two diferent things ,
                            1 that its ok to wire upto constant live aslong as you turn it off but someone said it should be ignition only live ,
                              erm, im not to sure then.. I just know one of the wires around the fag litter is ignition live because thats where I wired my gauges into and thats where the bloke a halfords wired into..
