Can you get flashed or lets say filmed going towards a gatso as i thought they only worke as you drive by.....Doing about 40 on a 30 yesterday and saw flash from otherside of raod as i approached gatso....Lines on both sides of road..
Gatso!!
Tags: None
Originally posted by vxrmarc View PostCan you get flashed or lets say filmed going towards a gatso as i thought they only worke as you drive by.....Doing about 40 on a 30 yesterday and saw flash from otherside of raod as i approached gatso....Lines on both sides of road..
they only work as you drive away from them
trust me ma mate does 70 past them all the time in his burgAstraEdition #105
If it was one of these then don't worry as they only work when you drive through them and not at them....
There is one on my way to work I like to set off. If I see anybody going through it I put my foot down and set it off, sooooo funny lol....
They probably thinking I was only doing 30 and shiiit themselves lol
But they wont get a ticket as its all worked out by the lines on the floor.
No other cars on road as 7am....
Jay how do you set it off?
Originally posted by vxrmarc View PostNo other cars on road as 7am....
Jay how do you set it off?AstraEdition #105
The fixed cameras are lane specific.
If its a rear facing camera i.e will get the back of your car it will be a bright flash, very noticable.
If its foward facing is a subtle flash as not to blind you.
I do not believe that its possible for a camera on the opposite side of the road to capture you if you 'happened' to be speeding, but knowing technology nowdays i dont risk it, then again i dont speed, lol.
Not very clever / mature JayJay with you being old bill!
Yes there were and i was doing 40 in a 30 because i actually rarley speed and presumed this was a 40 main road...
The ones that worry me are the new ones i saw on 5th gear. They are the ones that can have you over a distance and clock you on your average milage. So seeing it at the last min is no good cos it will clock you over a distance.Lasers are no good either because the camera will see you before the lazer sees the camera but i have been told that they are bringing out new lazers which work off a g.p.s. system to combat it.
There called SPEC camera's the ones that clock ur avrage speed over distance but they are **** and dont work very well:
http://www.thisislondon.co.uk/news/a...nes/article.do
P.s if you dont want to get caught by police laser guns buy a laser Pro park off me
http://www.openpitlane.co.uk/forum/s...ead.php?t=6252
Originally posted by vxrmarc View PostYes there were and i was doing 40 in a 30 because i actually rarley speed and presumed this was a 40 main road...
Originally posted by streamline View PostMarc don't worry it happened to me 2 weeks ago and i have worked out that it goes off because u sett the sensor off from the other side of the road, but it cant prosecute you from the other side of the road.
Originally posted by dale wootton View PostThe ones that worry me are the new ones i saw on 5th gear. They are the ones that can have you over a distance and clock you on your average milage. So seeing it at the last min is no good cos it will clock you over a distance.Lasers are no good either because the camera will see you before the lazer sees the camera but i have been told that they are bringing out new lazers which work off a g.p.s. system to combat it.
Originally posted by streamline View PostThere called SPEC camera's the ones that clock ur avrage speed over distance but they are **** and dont work very well:
http://www.openpitlane.co.uk/forum/s...ead.php?t=6252What a business man but that is a
vid.
