Pro Race 1.2 - Price & Size ? Brake Fitting Too
  • Pro Race 1.2 - Price & Size ? Brake Fitting Too
    Folks,
    I've done a search and there are other posts, but I'm starting a new one because I'm an idiot. I want the widest ones that fit, assume this is 235? Needs the cheapest place possible lol.
    I also need to ensure that the XYZ 355mm brakes will fit under them. I'm waiting on a pdf from XYZ but this website
    http://www.xyz-racing.com/brakekit4.php
    doesn't seem to have a pdf for the Astra-H. Hopefully they'll forward one on.
    Thanks for any help,info,links.
    Cheers,
    Al.
    Hi Again,
    I've attached fitting measurements, is anyone able to confirm that they'll fit under the Pro Race 1.2 18" ok? If not, who should I ask?
    Cheers,
    Al.
    Edit: I've already got decent quotes on price with tyres for the 235's. So if these brakes will fit I'll order em' up.
      XYZ slotted rotor is the best choice for those high performance applications, this rotor type helps to clear debris on the rotor, in addition, it can increase the bite characteristics of the brake pads. Cast iron rotor has 32mm thickness and arc vents for better cooling. The 355mm rotor requires a minimum 18" wheel.
      They fit under 18s Al
