My project Corsa, AKA Cecil
  • The new parts aren't ready unfortunately as there was a bit of a problem with the CNCing, but they are progressing.
    • Custom front upright number one completed with the bearing carrier I made, all dimensions have been checked so the 'production' pair can now be made.
      They should be much stiffer than the stock upright which I'm sure is flexing with the 50mm roll center corrector on, I'll be able to make steering arms to reduce/zero the bump steer and the bearing and drive shaft can be removed for rapid servicing without having to disturb any of the suspension components.
      • Level of work in this is outstanding mate!
        • Just gone from the start to current progress on this build and its refreshing to see something different on here and mainly some real fabrication work that's different to everything being about the power package.
          Looking forward to reading some more updates (Y)
          Standard VXR brake components available from http://stores.ebay.co.uk/Brakes-Inte...p2047675.l2563 brake caliper seal kits, caliper pistons, brake pad pin kits, Hel Performance hoses and much more
          • Just read this whole topic start to finish, I'm literally speechless.
            • Originally posted by X8 DUD View Post
              Glad you all like it..
              The uprights are finally finished so I collected them from the CNC shop this morning and here's a few comparison shots against the standard offering..
              All lined up awaiting the next step...
              Hopefully the CV joints will arrive before the weekend, I can then check and machine the back of the bearing housings for clearance on the joint, build up the bearing carriers, make a dummy strut to get the correct ride height and base camber angle which can then be used as a pattern for the front dampers to be built to and the uprights can go for anodising.
              • I haven't posted an update in a while so here goes.
                My clutch has arrived..
                I can now measure up for the bellhousing/adapter and check if i'm going to need a new input shaft too.
                The stock rad has sprung a leak so its time to investigate improving the packaging of the coolers as its super cramped in the front, the boost piping needs rerouting to avoid the oil pump on the sequential box and I've still got to add another rad for the new gearbox.
                First job, bumper removed to reveal the old rad layout..
                Old coolers out...
                Taller, thicker but narrower water rad located.
                Loads more space between it and the turbo, manifold etc.
                Engine oil cooler half mounted, it will probably get moved from this location once the new layout is proven.
                Welding department hard at work putting mountings on to the intercooler.
                Intercooler roughly in position, this reduces the total length of the turbo piperwork to around 800mm and significantly reduces the number of bends. The surface area of this intercooler is greater than the wide one and there are more tubes which should mean less pressure drop, the heat exchange efficiency of both rads should be better too without them being stacked. It will also be ducted from the bumper to ensure it gets lots of cool air through it.
                The beginnings of a light weight slam panel..
                • Slam panel finished.. Another 1.2Kgs saved
                  Pipework welded on to the intercooler..
                  and everything fitted in place.
                  • Wow, mental stuff good work fella
                    Arden Astra VXR WGM350 stage 4.5
                    Progress thread.......Instagram Chris.Lee 1973 http://www.vxronline.co.uk/forum/sho...uilt-Astra-VXR
                    W G Motorworks
                    • Originally posted by cklrossi View Post
                      Last evenings job was radiator ducting, so....
                      Cut some cardboard templates and then the proper pieces from 2mm polypropylene. Why white? because that's what i had!
                      Mock it up on the car.
                      Weld it together
                      Fit
                      Reinstall bumper.
                      Just waiting for a fan to arrive then I can go out for a drive and test the cooling system
                      • this is total wizardry well in buddy fantastic love following this thread!
                        • How the hell have i missed this for 3 whole years, .......... This is unbelievable work. Top marks Andrew, jealous much of your gift .... lol
                          • I thought a lot of work had gone into my corsa rally car but this project is epic!
                            • ye, it's epic, respect Man!
                              • Thanks chaps.
                                Here's what we've been working on the last few weekends...
                                First some aligami ..
                                Then add some bracketry..
                                Mount it in place..
                                Bolt in another piece (not custom made for a change!)
                                About as flat a floor as you can get on the back of a corsa.
                                Side shot from the mock up stage. It will probably get trimmed back once i've tripped over it a few times!
                                and from behind on the floor
                                There's just the rear mountings to finish off now, I have no idea if it will make any sort of difference but it looks cool IMHO
