My project Corsa, AKA Cecil
  • The last few weeks have seen the offside strut, hub etc fitted and I measured up for driveshafts, now waiting for prices and delivery schedules.
    Also plumbed in the hydraulic handbrake then bled the brakes and the clutch.
    Pulled the engine wiring harness to pieces..
    to add the extra wires for shift cut and gear potentiometer
    and started on a new switch panel..
    • Still waiting for driveshafts but i've got some bits n pieces done..
      Front brake pipes rerouted, the old way could see them catching on the driveshafts at the new ride height.
      Switch console getting closer to moulding
      Driveshaft support bracket mocked up, will complete it once the shafts arrive and i know its in the correct place.
      and an S1600 spoiler to duplicate
      • This is such a insane build can’t wait to see it completed
        xbox addy -turboyoda85
        Instagram yoda_craig85
        • Love this build!
          • Prepping the spoiler for moulding
            Shuttering up
            Making the mould
            Released from mould
            and the new switch console fresh from the mould
            • Made spoiler 'end fence' moulds
              First one out of the mould
              roughly trimmed
              started prepping the top side of the spoiler for moulding
              trimmed up side and base temporarily attached with tape, forgot to take a photo of the bare base moulding
              Switch panel trimmed and rivnuts glued in.
              cut out for removable panel
              installed awaiting switches.
              • Switch panel finished and brake bias adjuster installed.
                and near side spoiler end fence trimmed.
                • Originally posted by yodacraig View Post
                  You might be claiming your pension before you see that!
                  Only joking Andrew. Phenomenal work as per.
                  • Great project, love seeing updates on this! What's left on the jobs list?
                    Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
                    CS Mapped 285 BHP / 340 Ft.lbs
                    • Originally posted by Noxious89123 View Post
                      A lot of little finishing off jobs, underseal arches, paint floor underside, make a fuel tank cover etc and one major job, build the engine, which requires some custom bits as there's nothing really available for the 1.8.
                      Suck up..
                      • What's the thoughts behind sticking with the z18xe? Is it going to be for competition use, or as an epic track day car?
                        • Competition use, if I put in a z20lex (which parts are cheapish and available) then I would end up in the same classes as imprezzas, evos, m3s etc. If I build the z18xe with a slightly reduced capacity of 1760cc then the opposition should be more of a level playing field.
                          • Clever thinking! Are you thinking of putting it on ITBs or maybe going turbo? I'm guessing n/a.
                            • I'm sticking with the turbo..
                              • Finished the last spoiler mould, unfortunately there was a reaction with the spoiler so it needed a little repair.
                                Then pulled the top section
                                and trimmed and fitted it all together
                                The seam across the back shouldn't be so noticeable once its been flatted and clear coated
