K&N open cone filter
  • K&N open cone filter
    As above im selling as i prefere the look of the standard airbox and im planning on tidying my engine bay up.
    Its a really good filter which is also designed for the meriva.
    Its got all instructions and everything you need to fit, brackets etc.
    It hasnt got the cold air feed included, but these are only cheap plastic tubes.
    Good points.. Sounds awsome! You can hear the sucking and dumping and has a really nice induction noise, it also gives a slightly better throttle response, i really like it tbh, only selling beacause i like the look of the oe airbox and im wanting to spruce up my engine bay.
    Bad points.. the metal protective mesh is slightly bent as i fitted it too close to the engine for the 1st week or so and noticed it didnt have enough clearence. After noticing and fitting properly it was perfect. The actual filter isnt damaged.
    Pics..
    £50 collected from yorkshire area, will travell up to 20 mile to meet up. it cost me almost £100 iirc. Its been on the car around 8-10k. Its in perfect working order and sounds awsome, doesnt bring any lights up and the car runs perfect with it fitted.
