vectra c vxr cooler termo to the cooling system.
  • vectra c vxr cooler termo to the cooling system.
    hi
    anybody now if it is possible to get and cooler termo that opens earlyer then the original so the engine dont run so warm....?
    yes get one from a south africa spec car
    the better way would be a uprated Rad in the car to cool the water down better
    the truth is out there
    part GSI part VXR
      how do i get one from an south africa spec car....?
      i am looking in the radiator i am mailing with courtney if it there radiator could solve my problem with the specs i have meade on my car....
      but it would be cheaper with the termo....
        with the power your running a new thermostat wont make the car run any cooler
        what your going to need it a uprated alloy radiator to cool the water down better
        part GSI part VXR
          Happs, I would have a look at what angle your cooler is sitting at, as it must be stopping air getting thru to the water rad, if your running 100 degrees on your gauge, real temps must be merging on 120 and you will warp the head mate
            but the strange thing is that last summer there were no problems the problems this summer is after i had upgraded to the hybrid turbo.....
              you could fit a small water rad to cool the water down after the Turbo for under £200
              http://j-w-racing.co.uk/product.php/...beecbb430f8cb3
              part GSI part VXR
                http://www.autospecialists.co.uk/Foc...oduct-915.html
                this is setup I would fit in the car mount it infront of the car dead easy with all the room under the bumper
                part GSI part VXR
                  ask any good tuners they will say more power = more heat
                  you need to up the cooling system on cars to keep them cool or they just cook
                  part GSI part VXR
                    Tbh I'm stumped that MPG havnt brought out any cooling mods
                      Hmm this sounds very interesting, will this cool the super heated water from the turbo, or just aid in cooling the turbo itself?
                        it is wery interesting....it will cool the hot water from the turbo befor going back to the expansion tank and then there will not come turbo hot water back in the cooling system....
                        that i will try to look into....
                          they are good on the Turbo cars I had one on the cossie
                          along with uprated Rad
                          it cool's the water down kind of a pre Rad Cooler
                          well worth the money on high powered cars
                          part GSI part VXR
                            yes and i wonder iff not courtney has this in there desig and the radiator but wont show it on there webzite so other wont copy it...?
                              i am ordering the turbo cooler today....
                              here is and picture of it mounted in and sierra cosworth...
